1 - 20 of 30 Posts
Disadvantages:
- adds a lot of weight to the top of the car
- reduces headroom in the rear
- may leak/squeak/rattle
- can turn the car into a greenhouse if outside temp > 30C
Advantages:
that is a photo of a cayenne :) just an example of the ambience it creates.*
* background castle sold separately.
For me it's a no brainer, it really opens the car up, when it rains it's just magic.
Living in QLD it gets quite hot up here, my wife has a car with a panoramic roof and the heat is not a problem. Anyway the air con cools it down real fast.
I can't recommend it enough, once you've had one you can't go back :D
If we choice the panoramic roofing system together with the option heated and noise insulated glass option, will the pano glass upgrade at the same time?
On the Cayenne, the option only upgraded the side windows. The main benefit is insulation against extreme temperatures. I'm hoping the standard privacy tinting is enough to keep the temps down, otherwise I'll tint the fronts too.
Thanks Chylld, will tinted all windows, if I get the pano, will tinted it too.
How much tint percentage, that's the question?
Australian Macans come with privacy glass so rear and rear side windows are already tinted (to what % I don't know)
Pano roof is also tinted. I'll only do aftermarket tint if heat becomes a problem :)
Since this is in the Panoramic roof thread, I'll put this out there to avoid any confusion... This reveal is for the 991 Carerra Targa/Targa S models. :)
Reactions: -=Hot|Ice=-
The Detroit Auto Show will have the new Targa reveal, AND the Macan will accompany it as well. I intend to be there to see both these models (in the 911 family, the limited edition Targa is my fav).
if you're able to actually get in a Macan, can you sleuth out the model code? We just need the first three digits off of a Macan-specific part. They used to be obvious on the airbag warning stickers when the sun visors are flipped down. They may be more discrete now...
Edit - the airbag stickers are probably going to be the same as 991 or 981, so that's probably not a good source...
Discussion Starter · #20 ·
1 - 20 of 30 Posts
