21 - 35 of 35 Posts
Wondering if anyone installed an Oil catch can, I called Porsche North Houston and Service advisor was somewhat in the dark/ lack of knowledge about adding one. I'm wanting to add one, due to the higher oil temps and higher internal crank pressures [due to the added blow by from the turbo(s)] Then finding out how small the plastic/rubber tube is, to relief such pressure (and returning back into the combustion chamber) was actually very small in diameter.
Along with multiple complaints of how these Porsche Engines "Drink Oil" Which after doing a lot of research, shows it's a higher likelihood of the missing oil (levels) are created by this problem.
I've been looking for an Oil can that wont interfere with function and of course the small about of room we have to install/service this valuable add on.
If you added on, which brand, model, series and any other details which would help me and other fellow Macan Lovers.
Thank you.
This topic has been covered in another thread - which I'm merging with this one.
OP - a simple google search of: macan forum catch can would have revealed the pre-existing discussion
I just replaced my oil separators in my 2016 Macan - 117,000 miles. Took 10 minutes each! Super easy fix for engine whistle noise and erratic engine running. The dealer quoted me $1,400 with a discount to $1,250 plus tax! I purchased parts from Harper Porsche Jaguar. Here are the part order details. I would highly recommend doing your self. Its about as hard and putting gas in. Total cost $205.16 including shipping.
Part Number​
Part Name​
Price​
Quantity​
Total​
946-107-229-77​
Check Valve - Left​
$81.91​
1​
946-107-230-77Check Valve - Right$81.911
99970767740Check Valve O-Ring$8.582
99970767741Check Valve O-Ring$8.582
Thanks for the part numbers.
Did you take any pictures ?
What did the originals look like ?
A DIY guide would be great :)
2016 Macan T
Hi Teddis, I did not take pictures, unfortunately. But, no pics needed! Its very straight forward. They just pop off after you remove the 1 torx head bolt (I believe it is called that). If you don't have torx sockets you should get because you will need them eventually for something on the vehicle.
2017 Black Turbo PSE|PASM|SC|ACC
FWIW, our '17 Turbo had recently started this:
Brought it into a very quiet Carlsen Porsche for our appointment where I found the service department was not busy, they seemed to be just dialing in a Taycan Turbo S. (Photo below).
The service advisor diagnosed my problem as I pulled up. He said it sounds like a leak in the air oil separator(s), (also know as Non-Return Valves.)
The service department replaced both non-return valves even though only one was leaking air causing the whistle. Interestingly the repair parts list also included a CR2032 battery. They also performed the # ALA2 recall work for the fuel pump cover while the vehicle was there. All work performed at no charge to me.
231600
Have a 2017 GTS with 46,000 miles. Yesterday I got a warning "Engine Control Fault", Driving permitted, Consult dealer". Car was driving fine, no problems noted. Took it into the dealer and they had to replace 2 crankcase vent valves because they were leaking air. Tech showed me the part and it was plastic with a round diaphragm. Tech says he has seen this problem before but usually happens with higher mileage. My part failure was "premature". Part numbers 946-107-229-77 and 946-107-230-77. They sit underneath plastic engine cover so easy to access. Covered under warranty, parts would have cost $200 ($100 each) plus labor. While I was there, they also performed ALA2 Recall for Fuel Pump Cover. Picture of one of the valves attached. All is well:)
I wonder how many have failed and at what mileage.
Have no idea ..../but for a couple hundred dollars I look at it as cheap insurance against failure.
I’ll do this every few years or so.
2016 Macan T
You can replace them when they fail. No harm done when they fail.
Reactions: 95B3.6
So here is a pic of it disassembled.
Some Oil sludge was present at the engine port. Can’t say as I see much in the intake side, a Good thing I believe.
The Green O ring was turning Black....from heat I guess.
I wonder if we can source just the round rubber diaphragm piece.
2016 Macan T
21 - 35 of 35 Posts
