There seems to be a sufficient number of complaints to list oil leaks. Just like for the Transfer Cases, if you have this problem, please add to the bottom of this thread.
Please keep this thread strictly just reporting on if you have an oil leak problem, and only if you have a confirmed problem. That's why the thread is stickied, to document actual data, not as a general complaint thread. Don't post your car is OK. Don't post you want to complain about the quality of the cars or other complaints. Don't clutter it up with other comments. Don't add other complaints. This list is only about leaking oil
unclear if RL posts are duplicates of others in this forum
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 30,000
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 20,000
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 53,000 added to graph
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 19,500
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 52,000 added to graph
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 32,000 added to graph
Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums 10,000 added to graph
10/4/17 @goaliken Oil leak anyone?
10/18/17 @Photon Oil leak anyone?
10/19/17 @Vicbee 49,300 miles Oil leak anyone?
4/10/18 @ewoo Oil leak anyone?
6/12/18 @ehcan 23,000 miles Oil leak anyone?
7/18/18 @gleung604 Porsche Macan Recalls & Warranty
7/19/18 @c3uo 10,000 miles Porsche Macan Recalls & Warranty
7/31/18 30,000 miles Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums
8/21/18 @bajachick Porsche Macan Recalls & Warranty
8/21/18 johamill Porsche Macan Recalls & Warranty
8/21/18 @GTF 47,000 Porsche Macan Recalls & Warranty
9/20/18 @jeanmarie97 28,000 miles Porsche Macan Recalls & Warranty
9/26/18 @Pital Oil leak anyone? (not fixed?)
9/28/18 @ttmacan 50,900 miles Oil leak anyone?
10/21/18 @pschemacansd 19,900 Oil leak anyone?
11/13/18 @thelaw_thechef Porsche Macan Recalls & Warranty
1/3/19 @DustinM 25,000 miles Porsche Macan Recalls & Warranty
1/3/19 @TXRed ~34,500 miles Porsche Macan Recalls & Warranty
1/12/19 Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums
1/12/19 12,000 miles, Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums
1/12/19 @Jasonzhang 21,000 miles Porsche Macan Recalls & Warranty
1/17/19 @Arnold_T 16,000 miles Porsche Macan Recalls & Warranty
1/29/19 @Tiwilli Porsche Macan Recalls & Warranty
1/22/19 @16Turbo Swim Porsche Macan Recalls & Warranty
1/22/19 @Pudge Finkelhauser 49,200 miles Oil leak anyone?
1/28/19 @dnaren 16,500 Porsche Macan Recalls & Warranty
2/11/19 @ewoo 46,957 miles Oil Leaks
2/21/19 Cautionary Tale of Oil Leak (timing cover) - Rennlist - Porsche Discussion Forums
3/8/19 @bavenda I've been reduced to owning just a Can
3/15/19 @geauxldrush ~27,700 miles Oil Leaks
3/26/19 @parvo99 34,000 miles https://https://www.macanforum.com/.../complaints/169565-oil-leaks.html#post2518075
4/2/19 @sunster 80,000 Oil leak anyone?
4/4/19 @fuzzypixel 38,000 miles Oil leak anyone?
4/5/19 @big_nick 68,000 Oil leak anyone?
4/6/19 @german88 Oil leak anyone?
4/11/19 @ncmacan 50,000 Oil leak anyone?
4/20/19 @Firensteel007 26,000 Oil leak anyone?
4/21/19 @RidgeRunner0207 30,650 Oil Leaks
5/1/19 @[email protected]>@W 29,560 Oil Leaks
5/1/19 @Hbi_Evan 76,587 Oil Leaks
5/14/19 @schalup 46,000 Anyone with some high mileage on their Macan ?
6/2/19 @flash gordon Oil leak anyone?
6/11/19 @JFranklin 9,800 Oil leak anyone?
7/19/19 @mp96b 53,000 Oil leak anyone?
7/20/19 @Razor07 Which aftermarket warranty (if any) covers timing chain cover leak?
7/21/19 @Chrisrokc Oil leak anyone?
7/22/19 @Rosino 12,000 Oil leak anyone?
7/25/19 @flat6ix 36,000 Oil leak anyone?
8/8/19 @gregdhayes 48,000 16 macan s Transfer case replacement.
8/10/19 @Antaeus Woodson 21,900 Oil leak anyone?
8/13/19 @Paul Giovenco How many members DID NOT have transfer case or timing chain cover problems?
8/14/19 @Reuben Boyd 46,300 Oil leak anyone?
11/1/19 @hclax24 55,700 Porsche Macan Recalls & Warranty
12/15/19 @CGT 36,000 Oil leak anyone?
12/20/19 @shorton336, 65,000https://www.macanforum.com/threads/oil-leak-anyone.146697/page-18#post-2570359
12/28/19 @vancouver-porsche-matt 42,000 Oil Leaks
1/14/20 @phuture 30,000 Oil leak anyone?
1/19/20 @mattkeowen 40,000 Oil leak anyone?
2/17/20 @gburrell 22,000 Oil leak anyone?
2/17/20 @Benvo 49,000 Three issues so far after timing chain cover leak fix
2/18/20 @gburrell 22,000 Oil leak anyone?
2/18/20 @smohr33 11,000 Oil leak anyone?
3/22/20 @HazelPDX 27,500 Oil Leaks
4/18/20 @sg1 25,000 Oil leak anyone?
4/18/20 @BigMacVA Oil leak anyone?
5/6/20 @Sweeper 20,000 Oil leak anyone?
1/1/20
Porsche Macan - Cautionary Tale of Oil Leak (timing cover) - I recently bought a CPO '16 Macan S with 30K miles. A few weeks later I was learning about the new to me car and removed the lower engine cover to check out the oil filter location etc. When I did that I noticed oil on the lower...
rennlist.com
1/1/20
