Found out the extended warranty is still active. Scheduled appt and see how they will fix it..Warranty. My started leaking at 7K miles. It took 2 different dealerships to find and fix it. Dave T.
Not sure how long you have on your warranty but you’ll have to check their work. Took 7 appointments with 2 dealers to fix the leaks. Hopefully you have a better dealership than the one I bought from.
Good luck. Keep us posted.
Dave T.
Thanks. The dealer told me my case does not need the engine out. They didn't specific how many bolts. but these are the parts they said is leaking "valve cover, front timing chain cover bolts, and o-rings for cam adjusters." $4250 seems a lot for this fix.15k if the dealer does the engine out. Significantly cheaper if they do the 2 bolt method. Cheaper than that if you can do a 2 bolt fix through an Indy or yourself. Good luck
And this isn't part of the recall issue with the 6 cylinder cars?Thanks. The dealer told me my case does not need the engine out. They didn't specific how many bolts. but these are the parts they said is leaking "valve cover, front timing chain cover bolts, and o-rings for cam adjusters." $4250 seems a lot for this fix.
Not what I aware of. I searched online and didn't see related recalls. I filed a claim to Porsche NA and requested a quote to indy shop. Let's see if there are better/cheaper ways to fix this ...And this isn't part of the recall issue with the 6 cylinder cars?
Got it! How long have you done the fix? Do you notice any leak after the fix?Your drips are exactly where mine were and dealer removed and resealed both valve covers. The TCC bolt fix didn’t stop the dripping.
Dave T.
