Hello guys,
I have been working on my 2017 Macan Base 2.0 for quite some time and now have finalized the mechanical side and started working on the tuning side.
Mods done so far are as follows:
For the IS38 upgrade, you need some real good mechanical skills as it involves some cutting, disassambling, rotating the body etc. in order to make it fit to a longitudinal engine. As you may know, IS38 is usually used on transverse engines on Golf R's, MK7s etc. If anyone wants to pull the trigger on such an upgrade, I can share more details on the steps.
Engine is running smoothly. And for the tune, we are working with Jon @ Flat6Motorsports for a COBB protune.
We still have slight more to go until we reach the target boost and torque levels and then I will post the dyno results and times here. More than 420HP power is expected as the outcome. Stay tuned!
EDIT: Hello again,
After 22 files, our tuning efforts with Flat6 Motorsports that took more than 3 months has ended as they haven't managed to complete the fine tuning of the ECU. Flat6 has issued me a refund, which they were not happy about but anyway I have switched to Equilibrium Tuning (EQT) and they managed to tune the engine in only 2 hours with 6 files. Ed @ EQT is very experienced with these 2.0 TFSI engines. We are assuming that we are around 400hp with this beast at 1.9bar boost pressure. I am now going to pull the trigger on their Vortex XL turbo that will hopefully allow us to go up to 2.4 bar boost and 500whp.
Flat6 and EQT has night and day difference. EQT is smooth and factory-like, with no turbo flutter, no misfires, no leaning, no knock retards.
I am attaching the COBB datalogs from Flat6 motorsports and Equilibrium Tuning for you to compare.
EQT Datalog
Flat6 Motorsports Datalog
I'll edit more when I pull the trigger on the Vortex XL turbo, but for now, this base Macan can easily be called a Macan Turbo.
- The engine has 112k kilometers on it, it is rebuilt with Mahle forged pistons & rods: 2.0L TSI EA888 V2 Piston & Rod Kit by MAHLE & BAR-TEK® Bore is 83mm.
- OEM original IHI IS38 turbo installed
- Coils are replaced with these ones: High Performance ignition coils red BAR-TEK®
- Intercooler: 2.0L TSI EA888 Gen.3 MQB Intercooler V2 BAR-TEK®
- Spark plugs are Audi RS7 original spark plugs.
- Injectors are replaced with OEM new ones (all 8 of them)
- CTS Turbo Catch Can
- Downpipe (catless) installed
- AEM WMI system installed
- Fuel pump upgraded with Autotech internals.
- Alpha air filter installed. COBB Tuning - Alpha Performance Porsche Drop In Air Filter (1 Filter) Macan Base 2017-2018
EDIT: Hello again,
EQT Datalog
