Looking at a 2017 Macan GTS. The CPO has 24k less miles (32k miles) and is 9k more expensive than the used (56k miles). Used has launch control CPO does not.
A. Are there any good third party warranties for a used macan that actually provide for service?
B. What are the main concerns on a 2017 GTS and what are the general repair costs (so i can know whether i should just get the used and use the 9k difference for any repairs)?
Thank you!
Fewer miles is always an advantage - and with the CPO coverage, you can opt to continue with a "Porsche" plan when the CPO
warranty is about to expire, giving you additional warranty coverage. I think it's with Fidelity - and members will chime in if I'm incorrect.
Warranties cover failures for components that are not considered "normal wear & tear", just like the original or CPO warranties.
Used gets you in the brand (Porsche) at significant cost savings over buying new. The drawback is that the product is partially worn. That's
where warranty coverage comes in, and may be important.
A number of people advise, "Never own a Porsche without a warranty", reasoning that repairs can be
very co$tly. One can own and drive a
Porsche without a warranty, provided sufficient money is either set aside or always readily available to cover any instances of major failures.
I believe the advice noted above is sound - and a smart move on anyone's part (without a money tree growing in their back yard...).
Buying a Porsche is paying the price of admission - then one needs to be able to afford to live with it. Ensure you have at least one independent
Porsche specialist in your area as well as a Porsche dealership.
