Today I spent 6+ hours on redoing the Mr12volt unit. I decided to disassembled and replace the XM radio board, and to reroute the unit over to the passenger side instead of the driver side. Everything that could go wrong happened to me despite thinking I was more prepared than the last time around.
I bought some tools since the last install. I bought these finger saving tape so I could wrap my fingers tips so I didn't end up with abrased finger tips like the last time. I also bought a different vent remover than the one I used the last time around which I bought on Alibaba. I actually found a motorcycle spring hook and it worked perfectly, I also bought some cloth electrical tape, and circuit board spacers. Here's a photo of my bounty:
BTW, using the spring hook made removing the vents so much easier. And of course, using a flashlight this time instead of fumbling around the last time and breaking my vents...
First problem I ran into was when I was removing the Mr12volt from the driver side was that I couldn't pull the cable through. I guess it was easier to fish it through than pull it back out. While I was attempting this, I ended up pulling on some other cable and yanked out some sensor that was inside the steering column. I don't even know what it was and I didn't know where it came from but it just hanging there tangled up with my Mr12volt cable. So I had to pull out the trim piece under the steering column except I couldn't figure out how to fully remove it. I managed to loosen it enough to get my hand inside to finally put back that lose sensor.
I finally managed to pull the cable through and get the PCM unit out and opened the PCM unit to reinstall the XM radio board. I knew that the spacers that Mr12volt included wasn't long enough to put the Mr12volt board on top of the XM radio so my reason for purchase the extra ones. My second problem was that I couldn't match the spacers so that they were long enough to clear the XM radio board but not too long that the CD unit couldn't be put back. I didn't notice before but Mr12volt included spacer were 3 long ones and one short one. So after trying all possible combinations, I ended up just using 3 spacers instead of the 4. Then my third problem: as I was reassembling the PCM, I dropped one of the torx screws that held the screen to the CD unit. It fell in between so I had to open it up again, including removing the screen. I finally managed to get the screw out and as I was trying to reattach the CD ribbon cable, I ran into my fourth problem: since the Mr12volt board is now sitting so much higher (on top of the XM radio board), it was hard to reach in to reseat the CD ribbon cable. As I was trying to pull out the little ribbon cable lock, I accidentally pulled it lose breaking one of the tabs. I didn't know what to do, spent an hour Googling, and finally, I just got a needle nose plyers and just try 6 times to put the tab back in with the cable. I finally got it in to the point where I thought it was pretty solid and reassembled the PCM.
I had removed the passenger side trim and the glove compartment and routed the cables to the passenger side. Then I remember the Mr12volt microphone. I decided to just stick the microphone through the side of the vent up towards where the vents are on top of the dash next to the clock. I ended up reaching my hand through the vent hole, around the vent and up towards the underneath the dash. It stuck and I was happy with it although I forgot to test it. Oh well, I'll just have to live with it. I tried to take a pic but didn't really get a good focus on it. Here it is regardless:
As I was putting everything back I could figure out where to put the Mr12volt unit. I rewatched
@Santirx video couple of times but I could get the unit to reach past the cabin filter. I had to drop the glove box multiple times trying to pull the unit further out. In the end, I just managed to tuck it where it was and only used one of the 3 plastic screws to hold the thin foam cover.
After all this, the good news is everything is working. My AM and FM sound is back and the CarPlay is working as well. Didn't get to drive around and test it out fully. Will do that tomorrow. In addition to the 2 plastic screws I couldn't put back, one screwn under the glove box wouldn't go in. I think the Mr12volt cable might be in the way of the screw hole. I wasn't about to undo the glovebox again so I left it for now. Hopefully it doesn't cause any problems.
Quite the ordeal but I'm happy with the outcome so far. We will see how this fares in the long run.
