1 - 8 of 8 Posts
Hey guys, I have a brand new 0B5 series mechatronics to replace on a 2015 Macan, any help (procedural) on how to solve this using Piwis2?
I tried connecting with Piwis but could not. Any help?
233257
A PIWIS II is more than enough for that job, looks like your PIWIS is having issues and can't decode any faults, get the tester fixed and you'll be good to go.
The VCI unit is properly connected? USB light steady ON and COMM flashing?
Discussion Starter #3
can you help with the device? Obviously its not communicating with the vehicle
If the lights on the VCI are working as they should one solid and one blinking then is a software issue.
In that case we send the PIWIS to they guy that does the technical support to get it fixed, there's nothing we can do at the shop to fix that.
Discussion Starter #6
I need a heads up on the procedure. Its brand new TCU and do i need to go to programme or just do adaptation and coding?
Discussion Starter #8
I successfully programmed the unit and coded it but it shows blocked,any help?
1 - 8 of 8 Posts
