181 - 200 of 223 Posts
Mathematically it should be 20% louder but I actually still hear the sound stage to the driver left-ish. I have a 1ohm resistor on the way and might try it out later. I was just so impressed that I kept it as-is. Ace of base popped on XM which seemed to be a good all around test.
Glad you got everything installed. It truly is a huge difference.
I’d recommend testing with some higher quality audio sources too. XM is maybe 64 kbits/s whereas Spotify’s highest quality is 320 kbits/s. If using Spotify on iOS, I’d also recommend setting the volume option to ‘Quiet’ which will preserve more of the dynamics.
Good idea. What is that audio analyzing app btw?
Discussion Starter #186
Way back when we started these swaps I aquiredb the Burm mids , for doors.......with connectors....
I was hoping one might work for the Center, but it comes it at 2.7 ohms.
Dang.
2016 Macan T
V = I * R
Voltage should be constant (say 12V) and the current will go down if you increase the total resistance of the speaker. So 2.7 + 1 ohm from the dummy load should ~ equal the BOSE speaker.
Downside is that a speaker is not a pure resistor but also a inductor. Hence I recommended a non-inductive resistor to try and limit and impact to the fidelity. Another downside would be the wasted energy by the dummy resistor is put off as heat.
Power draw = V * I
FYI, I found this old thread which describes a simple solution to fix a bit of door rattling I was experiencing. This literally solved 90-95% of my issue.
It's amazing how much better the system is now with just a few changes (tweeters, sub, felt, and disconnected center). I am super-happy.
Hey guys tell me I’m not crazy here. Took out the sub box from my 2018 turbo and I have no amp on the sub enclosure. The sub says Bose on it, my door speaker grills say Bose on it. Am I missing something here? How is there not an amp connected to it like in @Draper pic?
Discussion Starter #200
If your OEM sub is working ......I can only assume they relocated the amp to somewhere they can actually get heat sink dissipation......or its part of one amp now ?
It is not too effective on a plastic box, like mine, LOL
2016 Macan T
