Hello All,
I did not see a post that had all of the speakers involved in the project so i thought i might start one.
Firstly, thank you to SirSchwag, Lippy et all,for all of the help with me so far.
FRONT DASH TWEETERS
So we know about the tweeters. BURM AMT's can go in with mods to the dash holes...but have a different impedance, so that needs to be considered. The Rear BURM tweets will replace the front BOSE ones, but you need to transplant the caps, shave male connector tab. Getter done
So lets move onto the other drivers:
CENTER: Can anyone confirm the impedance of the BOSE and BURM drivers? Also, has anyone gained access to this center speaker ? Does that center panel just pop off around the SC? If so, how ? Anyone have a diagram of the clips ?
FRONT DOORS (Mids) this looks like it is a straight swap, same impedance, no caps to add, remove door panel, Getter done
FRONT DOORS (Woofer) Can anyone confirm the IMP on both of the stock BOSE and BURM drivers ? Are they physically a straight drop in ?
REAR DOORS (Tweets) Straight replacement, no CAP required . Pop off panel, Getter done
REAR DOORS (Woofer) the Burm Rear woofers look and cost is different to the front woofers. Does anyone know the IPM of the BOSE driver and the BURM driver for the rear ?
SUB, undiscovered country as far as a speaker swap.
FRONT DASH TWEETERS
