1 - 13 of 13 Posts
Technical specs / data comparison between .2 GTS and Turbo. (Note: .2 denotes life cycle update on current Gen-I Macan)
The table below listed the differences on specs without options. Other specs, such as Engine (2.9L V6), Power transmission (Drive system, Transmission, Gear ratios), Chassis, Wheels and tires remained identical. Detail tech specs are attached for reference.
GTSTurbo
Max. power output (at engine speed)280 kW (380 PS) (5,200 – 6,700 rpm)324 kW (440 PS) (5,700 – 6,600 rpm)
Max. torque (at engine speed)520 Nm (384 ft lb) 1,750 – 5,000 rpm550 Nm (406 ft lb) 1,800 – 5,600 rpm
Suspension and damping
Steel suspension lowered by 10 mm and double-acting, hydraulic gas-filled vibration dampersSteel suspension and double-acting hydraulic gas-filled vibration dampers
Front Disc Brake Diameter / Thickness360mm / 36mm (cast iron)390mm / 38mm (PSCB)
Rear Disc Brake Diameter / Thickness330mm / 22mm (cast iron)356mm / 28mm (PSCB)
Length4,686 mm4,684 mm
Height1,609 mm1,624 mm
Track width, front1,650 mm1,645 mm
Track width, rear1,658 mm1,655 mm
Unladen weight according to DIN1,910kg (4,211 lbs)1945kg (4,288 lbs)
Top speed261 km/h270 km/h
0–60 mph
0 – 60 mph with S+
0–100km/h
0 – 100 km/h with S+
0 – 160 km/h
0 – 160 km/h with S+
0 – 200 km/h
0 – 200 km/h with S+
4.7 s
4.5 s
4.9 s
4.7 s
11.6 s
11.4 s
19.5 s
19.3 s
4.3 s
4.1 s
4.5 s
4.3 s
10.5 s
10.3 s
17.1 s
16.9 s
Fuel consumption
Urban
Extra-urban
Combined
12.1 l/100 km
8.0 l/100 km
9.6 l/100 km
12.2 l/100 km
8.4 l/100 km
9.8 l/100 km
CO2 emissions218 g/km224 g/km
Aerodynamics
Drag coefficient cd
Frontal area A
cd x A
0.36
2.62 m2
0.943 m2
0.37
2.63 m2
0.973 m2
Source:
GTS: Porsche Macan GTS : Macan GTS
Turbo: https://newsroom.porsche.com/en/press-kits/macan-turbo.html
The height is different . That is a big deal . Also the brakes on the Turbo are an upgrade .
Discussion Starter #5
I think the GTS suspension is lowered 15mm (not 10mm) ... which is the difference in height.
On the Porsche USA site the spec is identified as "height" if doing a side by side comparison of specs. Porsche Models - Porsche USA
Height
64.0 in
63.0 in
According to Porsche: Porsche Macan GTS : Chassis and chassis systems
The greatest strength of the new Macan GTS lies in its handling. Thanks to its standard Porsche Active Suspension Management system, including 15 mm lower suspension, the compact SUV handles like a sports car. Steel suspension, active damper system and anti-roll bars have all been completely revamped and retuned. This means even more driving pleasure through a more neutral response while at the same time offering unchanged stability and improved comfort. The new Macan GTS comes as standard with 20-inch RS Spyder Design wheels fitted with different-sized tyres front and back. The specially developed tyres contribute to the new model’s improved performance characteristics. Porsche Torque Vectoring Plus (PTV Plus) and height-adjustable air suspension are available as options to further enhance the dynamic performance of the car. Unlike the other Macan models, the chassis of the GTS is lowered a further 10 mm.
Adding both to 25 mm that is about 1 inch lowered (25.4mm), 63" vs 64". The GTS specs sheet only mentioned "Steel suspension lowered by 10 mm and double-acting, hydraulic gas-filled vibration dampers", without mentioning the PASM lowering figure.
Discussion Starter #6
The height is different. That is a big deal. Also the brakes on the Turbo are an upgrade .
Height can't upgraded unless going with aftermarket solution. Brake is the same with custom option.
One interesting note on stock Unladen weight according to DIN, it's 35kg (77 lb) lighter on GTS. Is 18-way seats and electronic steering column package that much weight difference compared to 8-way seats?
Unladen DIN Weight = Weight of Car with 90% fuel, no driver, no cargo.
I have always compared stock to stock and aftermarket to aftermarket . BTW great explanation above.
You are correct . The GTS comes with 8 way seats and Turbo with 18way . On a Turbo Porsche won't charge extra for the downgrade to 14 way . On a GTS 14 and 18 way are upgrades . They weigh more than the 8.
2018 Macan Turbo PP, 2013 911S manual, 1991 C4 Coupe
I had the 8-way seats on my first GTS, they "killed" me, never felt truly comfortable in them. The 18-way seats are a different story, love them, for the delta in $ it is one of the best upgrades possible.
These Porsche types apparently don't get the message that is turning out those impossibly crazy cars that come called things like the **** Cat Red eye. All they have to do is drop a crate engine in just one and it would be a classic.
GTSTurbo
0–60 mph
0 – 60 mph with S+
0–100km/h
0 – 160 km/h
0 – 200 km/h
4.7 s
4.5 s
4.9 s
4.7 s
11.6 s
11.4 s
19.5 s
19.3 s
4.3 s
4.1 s
4.5 s
4.3 s
10.5 s
10.3 s
17.1 s
16.9 s
Fuel consumption
Urban
Extra-urban
Combined
12.1 l/100 km
8.0 l/100 km
9.6 l/100 km
12.2 l/100 km
8.4 l/100 km
9.8 l/100 km
Aerodynamics
Drag coefficient cd
Frontal area A
cd x A
0.36
2.62 m2
0.943 m2
0.37
2.63 m2
0.973 m2
Source:
In the USA the GTS comes with the air suspension standard.
The GTS brakes appear to be the same as the S, based on the "Standard Features" for the S listed in the configurator:
Brakes
Front: 6-piston aluminum monobloc fixed calipers with 360 mm internally vented brake discs
Rear: Single-piston floating calipers with 330 mm internally vented brake discs
Brake calipers with Titanium finish
Anti-lock Braking System (ABS)
Multi-collision brake
Electronic parking brake
Brake pad wear indicators
Discussion Starter #13
Brakes
.2 S/GTS are basically the same braking system, with GTS brake calipers painted in red.
Base/S front track is the widest among all, while GTS rear track is the widest among all.
In general wider tracks will increase cornering power. Wider front track tend to reduce understeer.
.2BaseSGTSTurbo
Front Track1,655 mm (65.2 in)1,655 mm (65.2 in)1,650 mm (65.0 in)1,645 mm (64.8 in)
Rear Track1,651 mm (65.0 in)1,651 mm (65.0 in)1,658 mm (65.3 in)1,655 mm (65.2 in)
1 - 13 of 13 Posts
