The AS/PASM crowd probably feels the same way.I find the basic steel suspension to be absolutely fantastic in every way. In
RJust had HR springs installed. 1.5” lower in front 1.25“ in rear at the top of the wheel well, making the front a little lower than the rear over stock looks a lot better. Handles much better a little harder ride but not an issue if your used to 911’s.
I cant say about the kw kit but my bc kit still has a rake rears will only go so low u could take the rake out if u don't go that low but I think u would be better off keeping ur money and staying with the springs is just my opinion like I said I dont really know if the kw suffer like the bc coilovers in the rearHas anyone got long term reviews on the KW H.A.S kit?
I am leaning toward this kit to try even out the rear rake bias that the H&R springs have.
What is your other language? I need translation. Thanks.I cant say about the kw kit but my bc kit still has a rake rears will only go so low u could take the rake out if u don't go that low but I think u would be better off keeping ur money and staying with the springs is just my opinion like I said I dont really know if the kw suffer like the bc coilovers in the rear
How does it affect the drive?I am using Eibach ProKit coilspring and I think is the best OEM lowered look.
(Front 1.2" and Rear 1.0")
It does not affect the drive, I didn't see the difference. The lowering is only 1.2inch and 1.0inch, so it's not a big lowered.How does it affect the drive?
1. Road noise more or less?
2. The cornering?
3. The tire wear?
4. Any other thoughts before and after?
Thanks
Patrick
For me, I went to an independent service center to install the lowered springs and then the allingment.For those that had lowering springs installed, are you having the dealer install the springs? Or do you purchase and then go to an independent service center? Would any Porsche Authorized service center be able to do this install?
