No, not a problem.Anyone ?
I had the exact same issue here, just last week. It happens out of no where, and all of the sudden puddle of coolant on the floor. Car is in the shop right now.2021-01-11: I got the 'Coolant Level Low - Stop Driving Immediately' warning on the way to work this morning. Pulled over about 1/4 mile later, all temps looked fine on the display, the message went away after 30 s. The expansion tank had some fluid way below the min line and below the sensor. No obvious leaks so i assumed it was a progressive leak out of engine and evaporating or head gasket leak into cylinders or oil. Continued to drive to work, while making a service appointment and Porsche advised to top it off with distilled water until then. When i got to work, had a look again under the hood, a little steam coming from the front of the engine, maybe a leaking hose (hopefully!). 1 hour later the ground was covered in coolant, the engine lower cover wet all over.
So with a flat tow truck on the way, a rental car booked (no loaners available), I am hoping it is just a loose hose or some other inconvenience; which may be a result of Porsche pulling the engine out to fix the timing belt cover oil leak a few months ago.
Will let you know what the cause is.
I wonder would those plastic t shape hose just wore it self out, or is something else causing the engine to heat up and led to the breakage of the t shape hose?Had the same issue as described by the original post. It was an upper coolant hose connector shaped like a T and it had to be replaced. Technician said it crumbled into pieces because of the immense heat that comes off the top of the engine. I look at this as a design flaw, that piece should be metal or aluminum, not plastic. My coolant tank was bone dry and I poured 32 oz. of bottled Aquafina water into the tank so that I could drive car 10 miles to the dealer. Error code went away with the temporary fix. Tech said that was OK to get the car to the dealer.
After the new T connector installed, all is well. Be careful of a wrong diagnosis and expensive water pump repair...
