81 - 100 of 123 Posts
· Registered
@Santirx i have asked him but Mine is MY18 and when specialist plugged in PWIS he was able to code the option (LED PDLS) and was able to see all other options regarding LED as well he showed me too . this is where it gets really problematic as No one is able to confirm these things 100% and so many options from country to country and even CAR to CAR are different.
Kit has the all the modules and shop is able to code , I guess there is no way to confirm unless you try . on top of this Suncoast emailed saying that my VIN is compatible with the upgrade . Its really bad i'd say , we should be able to upgrade as we wish . my disappointment of Buying a Porsche keeps getting worse and worse . I am the only one responsible for making the decisions but having owned EURO cars from last 20 odd years this has to be most limiting out there .
OK… yeah, I guess that’s the only option then.
· Vendor
I have a 2018 Macan S with Bi Xenon PDLS. I picked up a set of PDLS+ LED headlights from RADHAUS. I'm installing them next week and having Porsche code them in on the 6th. Will update with the results.
Keep us posted :)
· Registered
Macan S MY18
@mac_flyer9 Please Do keep us posted , I am holding off my purchase until you provide this crucial info . I will still love those lights as i think they provide a good update on outlook making the car look more modern but its good to know what should I be expecting . Would you mid posting the The camera portion of your car , just wish to see if its same as mine as it would clarify one concern . I have posted mine in this thread .
@RADHAUS did you ever found out what happened with this retrofit on non-pdls cars , So far the information I have is that if Hardware is present then it should work regardless. it needs to have a camera for those functions and level sensor which is already present with my Bi-xenon . The kit i was going to get has other components bundled in .
I did see Flat 6 video but they did not disclose if the car was PDLS or non PDLS. also watched a Malaysian car shop video and it was straight swap in that too LED retrofit on Halogen Lights. Notice at the end car has camera , I see some splicing though so not 100% sure .
In this LED retrofit Video the OP also responded that all functions work with coding of course on Bi-xenon models but not on Halogen ones .
· Registered
I installed the lights today. No issues, though take your time with the electrical connector clip, can be challenging. Taking my time, it took about 45mins. Lights came on when I started it up. No DRLS or brights though. Im assuming the programming will take care of that. Pictures of the lights and the error that came up after engine start.
Speedometer Plant Vehicle Car Motor vehicle
Automotive parking light Land vehicle Vehicle Tire Grille
Automotive parking light Grille Automotive tire Automotive lighting Vehicle
· Registered
Discussion Starter · #86 ·
looking good - I didn't get any error messages initially after install but I'm sure once coding is complete everything will work perfectly
· Registered
I think this is all coding related. Certainly the 4-points not coming on is coding related.
· Registered
Macan S MY18
They Look great , well done ! , I look forward to hearing the rest after coding .
· Registered
Currently at the Porsche Dealer/Service for coding. The tech attempted programming just the lights and it failed 3 times. He then recoded the entire car. Success!
Billed for ~2.5 hrs of work. Standard Porsche Tax.... I am happy with the service though, they scheduled me in a reasonable amount of time, accommodated my coding request and were successful.
· Registered
Here is a closeup of my camera. Car has LCA, and LKA.
Hood Automotive tire Motor vehicle Automotive lighting Wood
Yeah, its a crummy picture, but should suffice. lol
· Registered
I was out at a movie last night and now have some feedback for the new lights. This is my totally subjective opinion, the LED low beam pattern appears whiter, brighter and wider than the Bi-Xenon pattern. The turning lights were very noticeable. I used the high beams once, just to see if I could tell the difference, I couldn't tell much except as with the low beams, the light appears whiter.
So, in subjective summation, I'm very happy with the update. Both the visual and light updates were worth the cost.
· Registered
In case it helps anyone - I used to have halogen on H7; H11; and Fogs and I changed all of them to LEDs. Dealer was able to correctly level the lights.
H7; H11 - LEDPERF Macan Conversion Kit - High Power LED Bulbs Conversion Kit for Porsche Macan - 5 Year Warranty !
NOTE: The H11 stays in "High Beam" even during the day so I either use the low beams as DRLs or just keep them as is - during the day it is not as visible
Do not buy the LEDPERF Fog lights as they will not fit the stock enclosure. Go for the Morimoto
Fog Lights - Morimoto - https://www.morimotohid.com/morimoto-porsche-xb-led-fog-lights
Easy install and includes housing; used the white knobs in the back of the housing to level. These look beautiful and help so much.
Some pictures below - First is H7 + Fog Lights; Second is just Fog Lights.
· Registered
Macan S MY18
@Miras Don't believe they are Porsche Genuine unfortunately , Try the Original OEM Sellers and you may get lucky with a full kit Put together the Parts . I am going to do it soon as soon as I get some extra cash that i am ready to burn .
If your Car has PDLS+ they would work But from picture i can tell they are updated model which is not the right fit and I would not recommend those at all.
But hey I ain't your DAD so you do you mate ;) !
