Thanks FE.
Large amounts of "aesthetics and packaging" on the road these days, making a comfortable ride quite a suspension design challenge
Edit: A question FE, if you don't mind. It looks as though the minimum wheel diameter possible is 18", to clear the calipers, though I'm wondering if there's wheels with rims that are not as deep, meaning a 17" might be possible if the actual rim [might be using the wrong term here] was lower profile. Maybe steel would have better strength/thickness properties?
,Lower profile does not necessarily give better lateral grip, but often it signifies what an engineer is trying to achieve - as such it often does mean exactly that. (With a performance road car it can simply be aesthetics and packaging).
Of course another approach for me might be to get in a grader.Also needs to be remembered that tyres form part of a whole suspension system (which even also include chassis rigidity). So what you are trying to achieve needs to be considered as exactly that. What works for one setup may be horrific on another.
