1 - 5 of 5 Posts
I have a giant book (Atlas Shrugged) on 50 CDs. Each CD contains 20-25 3-min files. I converted them to MP-3 and downloaded all of it on a USB drive. The files are named Disk1(1), Disk1(2), and so on. When I tried to play it today, it played Disk1(1), Disk1(10), ..... Disk1(19), Disk1(2), Disk1(20), etc.
When I plug the USB into the computer, all files are listed in correct order. So, the PCM is somehow is mixing them in this weird order. Is there any way to make it play the files in the correct order?
This is what I see on PCM:
231990
231991
And this is what I see on the computer (the correct order)
231992
Discussion Starter #3
The listing order on the PCM is alphabetical. Simply rename all the (1) (2) (3) etc. into (01) (02) (03)...
I did. It still plays File 1,11,12,....19, then 2,20,21,22....etc. I tried downloading it on my phone and playing if with bluetooth, I even burned a DVD and played it. Same thing. I ran out of options. Any other ideas?
You missed the two digit numbers for 1-9 that @Sly_North suggested. It needs to be 01, 02, etc. Not 1, 2, etc
I have mine named similar (with leading zeros), and it works.
1 - 5 of 5 Posts
