1 - 6 of 6 Posts
My wife drive a '13 C63 AMG w Dev Pkg. It's been blowing blue smoke on restarts. After the engine warms up then sits for 15-30 minutes and you restart it.... Watch out mosquitos.
The AMG forum says they all do that. Make a long story short, I wanted to install a Weistec catch can and have the PCV swapped out. Benz wouldn't do it; the catch can was not "OEM". I found TGA (Texas German Autohous) at 3417 Edloe St, Houston, TX 77027. I worked with Matt, the owner. To do it right, I had him remove the intake manifold. Clean everything out. New plugs. New intake gaskets. New PCV and catch can installed. He did a really good job in routing the tubing to not interfere with the dip stick and fabricated a bracket to securely mount the can instead of using the cheap clips from the kit. Threw in a rear diff fluid change. Total was $1,900 out the door. Little-to-no smoke now on restarts and feels like it gained about 30HP.
When the time comes to change out any fluids in my Macan, I'll be taking it there. Filters, oil changes and plugs I can do myself. Here's their website: https://t-g-a.com
When the time comes to change out any fluids in my Macan, I'll be taking it there. Filters, oil changes and plugs I can do myself. Here's their website: Home - Texas-German Autohaus
Bruce, thanks for posting this. I might be heading that way to get my GTS fixed...eventually, we shall see. Your original post as almost a year ago, has anything changed since then at this place? Do you still recommend this place today?
His original post was for an AMG Benz - not sure it's been done on a Macan.
Oh, my post was meant as an inquiry about the repair shop if they are still reputable today, for Porsche repairs.
I wasnt referring to retrofitting the AMG catchall on my Macan at all LOL.
Discussion Starter #6
Everything is working perfectly. My son bought my wife's car (the 2013). On the rarest of occasions, it might blow a small cloud but nothing like what it was. The Weistec is expensive. However, the fittings are made specifically for the W204. I went that way instead of a generic solution. I wasn't doing something half-a$$ed on a car of that caliber.
1 - 6 of 6 Posts
