New to us owner of a 2017 Macan S. I have another turbo car, single turbo 235i, so I am used to turbos. I am getting a high pitch squeak, squeal, what almost sounds like a belt chirp. Or, when you go to the dentist, the high pitch metallic noise. I have spent some time looking in to this, my mid pipe bracket is all good, I do not have any noises at idle, or while revving in neutral. I am thinking diverter valve or maybe early sign of the oil separator? Could it be a boost leak? I have a bout 5 more months on my warranty, so curious if there is a concern here or if I am just being over sensitive.
Here is a video that if you listen closely you can hear. It is much more pronounced in person. I notice it under moderate acceleration through about 4th gear. It sounds to be turbo related as it makes noise when the turbo would be engaging or when I am letting off the gas after moderate acceleration. I do not hear it on the passenger side.
Thoughts, questions, suggestions?
