1 - 5 of 5 Posts
2021 Macan GTS. I recently built a garage and now that it is colder I no longer keep the garage windows opened. Since then, there's a slight gas smell when I enter the garage. At first I thought it was from my "old" 2006 911 but this morning I took the Macan out of the garage and the smell is gone!
So it looks like it originates from the Macan. I don't see any leaks on the floor nor do I smell gas in the cabin. It seems like it is coming from the fuel trap door. Of course that's right there when I use the service door so perhaps it's "normal" that I smell some gas since it's right in front of me when I go in the garage?
I know there was a recall for older models but was wondering if anyone else has experienced this on more recent models?
How about the possibility that opening the LARGE garage door when you removed the Macan allowed the gas fumes to dissipate?
Try this experiment: leave the 911 in the garage overnight and the Macan outside. See if you smell gas in the morning. I believe it is
more likely the older vehicle is leaking a bit of fuel and this trial will help to determine whether or not that is the case.
Discussion Starter · #3 ·
Yes, the Macan is currently out of the garage and will remain there until tonight. The only thing I can think of is that I did add some Boostane in the 911 the day before and some splashed around when I poured it at the gas station. That liquid stinks a lot!
It's not a smell that lasts. You can smell it when entering the garage and it disappears within seconds. It's not like a huge gas smell that lasts.
Maybe the smell originates from that. I washed the 911 today, including behind the fuel door so we'll see...
What year is your Macan, if I recall there was a recall that gas could leak into the vehicle but forgot exactly what it entailed
1 - 5 of 5 Posts
