Product:
Flat 6 Motorsports High Flow Intake System
Retailer:
Flat 6 Motorsports
Discounted Price:
$400.00 USD 37% Saving was $639.00 USD
Valid Until:
Jul 2, 2022
San Diego, California
Deal Link:
Im selling a great condition CARBON FIBER AIR FILTER from Flat6 Motorsports
My car: 2019 Macan S (No longer have and got a 2022 Cayenne)
I can't use it and will sell to a member for almost half the price. I have pics and will upload them.
Other item for sale:
selling for cheap, rather get good karma and help out a fellow Macan member. I'm located in San Diego for local pick up in Public place like starbucks etc.
PowerControl RX Module by DTE (Macan S 19+)
Product Details
The Flat 6 Motorsports High Flow Intake System is the most advanced engineered intake system available for the Porsche Macan. Aided by CFD analysis, we optimized the intake air flow, providing a maximum power increase. The free flow intake ducts paired with the bell-horn shape and proprietary filter media creates an optimum surface to distribute air inside the factory airbox to maximize air velocity and flow. This system integrates directly to the factory airbox enabling a simple installation and OEM fit & finish.
This system includes:
Recommended: Cobb Optimized Stage 1+ Map
Features
  • Direct Factory Replacement
  • Significant Flow Rate Enhancement
  • Dyno verified 10whp on the Macan Turbo
  • 1/4 mile verified improvement of .271 sec and 4.34 mph higher trap speed
  • Improved Turbo and Throttle Response
  • Tested below 1 micron to ANSI/ASHRAE Standard
  • Nano-Fiber Dry Media Filtration
  • Simple Drop-In Design
  • Easy to Service
  • Made in the USA
Engineered
Porsche provided an excellent cold-air delivery solution by leveraging ducts from the front grill that feeds air up through the hood and down into the air filter boxes. One area they left room for improvement on is the design in which air velocity can be manipulated to increase power. They split the air channels into two runners and placed a duct with a large area in the middle to drive the air flow into two chambers in the airbox. Because of this, they only put two filter surface areas to bring air in. This keeps air pressure high on the outside of the filter but slows the velocity at which air can pass through the filter and into the charge pipe leading to the turbocharger.
After studying and analyzing this design, Flat 6 Motorsports developed a solution that was cost-effective and simple to install and service. The first principle was to increase the air flow in volume and in velocity. We achieved this by opening up the duct that connects to the hood to allow more air flow into the airbox. We then used CFD analysis to optimize the design of the air filter media. Advanced simulation software showed that a bell-horn like design would both maximize filter surface area and most efficiently distribute air flow around the filter which provides 360 degrees of material compared to just 180 degrees on the OEM filter. This design creates high-pressure on the outside of the filter while minimizing pressure drop inside the filter, causing an increase in stable high velocity air that leads to the turbocharger.
Materials
We chose to use the finest grade materials including a pre-preg dry carbon fiber with 2x2 weave to provide lightweight and stylish design to the top of the intake ducts or available in high-temp carbon composite. If every ounce of weight matters to you, you'll be glad to know the High Flow Intake Ducts reduce weight by 68% compared to the factory tops. For the filters, we leveraged a world-class supplier who's industry leading proprietary filter utilizes a dry synthetic multi-layer material. The dry fiber technology enables maximum airflow with minimal pressure drop and efficient filtration.
Installation
Installation is simple for this system which makes any able body the right fit for this DIY job. All that is required is simply removing 4 screws from the OEM top, removing the OEM filter and replacing it with the Flat 6 Motorsports High Flow Filter, then reusing the gasket on the Intake Ducts and bolting down the ducts to the OEM airbox. This job can be done in 15 minutes with a T-30 or T-25 torx bit. Detailed installation instructions are included with every order. Click here for the 2.0L base or Diesel S instructions.
Installation Instructions
Dyno Plots
1/4 Mile Testing - Results
Macan S Quarter Mile Plot
Macan S - Quarter Mile w/ Intakes
