1 - 5 of 5 Posts
Hello guys.
2015 Macan S, just got the "check engine light" on.
can anyone help me understand what this fault code means?
this is a screenshot from the durametric software.
Thanks in advance.
228492
Looks like it is pending a DTC. So a register is incrementing the number of occurrences of some fault, before it triggers a DTC. I would just wait for it, as it may clear.
Discussion Starter #4
thanks guys.
i will wait for the weekend to try and also have a hard reset by disconnecting the battery for 10 minutes or so. if it will not clear, i will contact durametric support.
Discussion Starter #5
Hi guys.
just wanted to close the loop in case someone comes across this issue.
as justsam suggested, the code has cleared itself. i planed on disconnecting the battery over the weekend, but the code cleared itself on sunday morning (today is Tuesday) and since did not came back.
thanks again for your input.
1 - 5 of 5 Posts
