DIAYOR = Do It At Your Own Risk
The PCM 3.1 has a 100GB hard disk drive (HDD) storing critical information for its function. The HDD has mechanical parts and may be prone to failure. When the hard disk drive fails, it loses information that ties your PCM to your car and options and will render your PCM inoperable. When you take your car to Porsche, they will charge a steep amount to fix the issue, normally replacing the whole PCM (around $4,000).
I was successful in cloning the hard disk drive (HDD) into a solid state drive (SSD).
Before I start, I want to thank @Teddis for all his suggestions and guidance.
It starts with the removal of the PCM 3.1. Fortunately, you don’t have to disconnect it, but slide it forward as you’ll have access to the HHD from the top.
STEP 1: Take out the PCM fuse - In the trunk, fuse bank E, fuse # 2 (10 amps). Consult the manual.
STEP 2: Remove the driver’s and passenger’s trim. Use a hook. Mark the hook as seen in the photo. It will be useful to know when you are truly hooked to the right part of the vents.
Here is a video on how to take the trims out (click on image below)…
Taking Porsche Trim Out by santirx macan, on Flickr
STEP 3: Remove the 4 screws holding the PCM in place. Use a T-25 Torx bit.
STEP 4: It is better if you turn the key to the on position (without turning on the car) and put the shift gear in drive. That will allow you to slide the PCM forward. I recommend you put a towel on the center console so that you can rest the PCM on top. You don’t have to disconnect the PCM quad harness nor any of the wires.
You’ll get access to the hard disk drive which is on top of the PCM…
STEP 5: Unscrew the HDD screws (two of them), break the seal and pull the HDD out.
At this point, you can either remove the 4 screws on the side of the HDD assembly to be able to remove the HDD, or you can remove the ribbon cable by lifting the white holder carefully and pulling the ribbon out.
This is the PCM with the HDD removed.
To be continued…
To be continued…
