21 - 35 of 35 Posts
2020 Macan Base/Black on Black
I got them because I felt the handles looked unfinished without them. As others have said, good place to store your wallet in the drive thru line; your face mask etc. Agreed not very deep, but given the lack of storage otherwise, worth the $16 investment
OK- mine arrived.
Today's model might be an improvement -
They have a rubber liner on the bottom to prevent/reduce rattle
Each lateral side (outside) has rubber -
Might be to prevent damage as depicted in the photo posted here
Yes - I tried to reduce the area where we saw the damage...
I shaved some off w/ a knife... and rubbed it on cement to 'finish' the job.
No tools - not at home this weekend
After 2 hrs - showing a small indentation (per photo) further in from the corners
But then - Am I ever going to remove them ???
I doubt it.....
I may get around to a photo
Also got this - clips onto the dash
242933
Thanks, just what I needed. I bought a beige 54F2CD8B-9CB2-47A4-9F8D-9303B96671F0.jpeg set. I comes with a non-slip bottom rubber liner. I just need to quickly drop off or pick up small stuff rather than throw on the passenger seat and then have slide off when I turn or brake. I plan to leave them on the car.
242934
OK - I’m gonna say it again. These things put creases in your door panel that don’t come out. I don’t even have the leather doors and the creases won’t come out of the passenger panel, even after a few days in the sun.
I trimmed mine down to reduce/eliminate the problem,
but on the other hand - I doubt I will ever remove them.... so not an issue
very convenient & good looking
I like them.....
I bought mine on Amazon and they DO NOT leave a crease in the leather.
Amazon here too......
That's where I bought mine (the LFTOPP ones).
Glad you're not having the problem! I miss mine, but they put creases in all four doors (only one door is permanently creased). Maybe I should just suck it up and put them back in. Could just be because I have the plastic door panels, not the leather ones.
Can you post the specific link to the ones you bought? There are multiple listings.
Bought these. Going back. Super cheesy. And after about a minute left crease. Can’t imaging after some time. Pass
21 - 35 of 35 Posts
