1 - 20 of 160 Posts
Has anyone else here had a crack develop in their door handle? Mine is on the driver's side rear door. I don't see any indication of impact. Very strange.
The crack looks like pressure damage from a Vice-Grip tool, like on purpose rather then from a manufacturing defect.
Almost looks like some took a razor blade to it. I hope Porsche see's it differently so you are covered but to me it looks like some kind of damage rather than a manufacturing defect. Could also be something that you were transporting in the back that caused this like luggage?
Discussion Starter · #6 ·
This is the outside door handle.
Had very similar, not as bad but on both handles on one side.
Never found out what the cause was. Got new handles, resprayed and replaced.
Good opportunity to get the gloss black handles.
Jk. That sucks but does look like external damage caused, not happenstance or defect. Hopefully they will just replace it.
For all who have had door handles crack on their Macans, do you live in a cold climate?
Maybe the handles are made from an inferior grade plastic that gets brittle when cold.
:confused:
Discussion Starter · #12 ·
I was thinking that as well. Not particularly cold here, but we get into the sub-freezing temps for a bit, down to around 20 degrees F. Not that cold compared to Chicago, Toronto, etc.
Mine shows similar problem on three of the handles. Not sure what caused it. Would like to hear from folks reported sane problem if they manage to get Porsche to replace them under warranty.
Where do you live? I'm in Bellingham, WA.
Also, how old is your car? I got mine in September 2014.
Certainly could be a manufacturing defect, similar to the cracks in the B-pillar that many people have encountered...What did the dealer say?
Reactions: SoCalS5 and ABusLux
Discussion Starter · #15 ·
Dealer said that Porsche very rarely covers these types of issues under warranty. I personally think it is a defect in the material or the molding process.
The biggest pain is getting a door handle painted. The part is expensive (it is the whole assembly). If I remove the old one I might cut it apart and see if I can prove problems with the handle.
Hairline crack on my driver door handle too!!!
Saw it earlier today.
Looks just like the pics attached to this thread.
Just purchased the Macan on Dec 30th too. I live in SoFlo...so no to "extreme cold" as the culprit.
Did the dealer cover this?
Will call them tomorrow..
I suspect this is a manufacturing/QC issue..
Will post pic later.
***re-read... I see Ivan's dealer did not cover this under warranty.
That sucks....and irritates me.
I have less than 3k miles on my Macan too.
How much is the assembly?
Did your dealer offer to cover anything??
Discussion Starter · #19 ·
To be clear I only spoke to the dealer about it and haven't done anything yet. Going to go back and continue the discussion.
Be sure to mention this thread when you go, and good luck!
All I know is if stuff like this ever happened to my Mercedes, the dealership wouldn't even hesitate, and would just replace the door handle(s).
Reactions: SoCalS5
1 - 20 of 160 Posts
