1 - 4 of 4 Posts
I hear a clung sound coming from the driver side mid section underneath?
I inspected the muffler, exhaust pipes, collars, front and rear suspension and everthing vizually looks tight and all rubber.
It does not happen all the time, most often when you are stopped and when starting being aggresive you hear a clung?
Any suggestions to inpsect?
There's any pattern for the noise to happen? shifting from 1st to 2nd, 2nd to 3rd? upshifting downshifting?
I had a few of those sounded like something hitting a heat shield, and found that it was the PDK when shifted from second to third and same when downshifting.
Discussion Starter #3
I think it is the cardone shaft,the shaft wobbles. I read the Cayenne has the same problem?
Trying to see if there is a any third parties that make a bearing fix?
Yes, it's a very common issue on the Cayenne but never heard of it on the Macan/Q5.
The part itself it's quite cheap, around 450 for the GKN unit which is the same as the factory one.
How many miles on your car?
1 - 4 of 4 Posts
