1 - 8 of 8 Posts
Hey guys, I have a loose wire on my cargraphic harness. I need some assistance on where this black wire goes. I think it goes underneath the red wire... but not sure. Better safe to ask than to fry something....
240258
240259
240260
Discussion Starter · #2 ·
Bump, if anyone can confirm pin location and or provide of the harness to the module it self.
Yes - as you suggested, it goes below the red wire. I took a photo with my phone two days ago and had issues getting it to AirDrop to my MacBook.
Still having the AirDrop issue... Rebooted the phone - now it (MacBook) shows up...
240361
You may have noticed that I have pulled the WHT/YEL and WHT/BRN pins on my plug. That is to keep the low
mode at 50+ MPH. My unit is from 2017 and the "trick" was to remove those lines so that the unit wouldn't default
to "normal" ride height once the 50 MPH threshold was crossed.
I believe this is/was discussed in the "Wow, Wow, Wow" thread.
I have them each taped up and held back.
You can barely make out the WHT/BRN line in the photo.
is that all there is to it? unpin the 4th and 5th wires?
Yes, AFAIK.
Be sure to wrap the ends or snip off the connectors so that any signal they may carry will not arc/short against a metal surface.
I've been running with this configuration for 4 years.
For more info, check the thread I referenced above.
Discussion Starter · #8 ·
Weird, when I’m in sport plus it raises a bit. I usually notice it when I leave the car and lock the car it purges air and lowers.
1 - 8 of 8 Posts
