1 - 2 of 2 Posts
Fabspeed Motorsport USA was the 1st company in the World to design and perfect Porsche Macan exhaust systems. Fabspeed is the brand to trust as we have the most experience with these cars.
True highflow slip on high performance exhaust system. Improves power, exhaust tone, and saves weight by replacing the factory OEM heavy restrictive stamped mufflers.
241932
The Porsche Macan is Porsche’s most popular model and boasts the highest volume of sales. The Macan is a true enthusiast car and dramatically benefits from a Fabspeed Sport Cat. You’ll appreciate the more aggressive exhaust note and significant horsepower increase.
These are the largest and highest flowing catalytic converters on the market for the 2019+ Macan 2.0 liter 4 cylinder turbocharged car. We use HJS German Imported 200 CPSI trimetallic EXTRA LARGE catalyst cores which allow for maximum exhaust flow with the world's very best catalysts efficiency for emissions compliant reliable power. Fabspeed engineers have worked tirelessly to create a direct bolt-on replacement for the heavy & restrictive factory Macan single catalytic converter that is 700 cell ceramic core that is 10” 250mm long.
Our Fabspeed engineers immediately found an opportunity for improvement to the OEM stock Porsche catalyst system when they found a restrictive OEM 700 cell ceramic catalytic converter. The OEM Cat restricts exhaust CFM flow, limits sound, and worst of all, robs performance. Replacing the OEM cat for a Fabspeed Sport Cat will net you improved performance with absolutely zero fear of a check engine light.
241931
Reactions: Juan Blanco
Discussion Starter · #2 ·
Why We Choose HJS Catalytic Converters:
HJS German imported catalytic substrate cores are made by EMITEC utilizing the highest grade stainless steel materials and Tri-metallic precious metal wash coats for high performance street and racing competition usage. HJS German 200 cell Trimetallic Euro 6 HE catalytic converters give the highest performance gains, improved sports car sound and maximum durability. Other brands of catalytic converters immediately deteriorate and fail over time as is typical. Some Asian companies and brands DO NOT even offer catalytic converters as they know that their catalytic converters will NOT work even when 100% brand new as they have no reliable quality solutions. The HJS German imported HD catalytic converters flow up to 90-92% of a straight pipe in most applications. The benefit is that you get the "straight pipe sound" while still being able to provide enough emissions scrubbing to prevent a check engine light. Typically no P420 and no P430 codes and your car smells clean with no need for a tune to pass emissions testing. It’s a Win Win solution for a sportier sound, more power, and a cleaner running car which prevents pollution. No short cuts ever.
FEATURES:
  • Fits all Porsche Macan 2.0L I4 Macan 2018+ vehicles that do NOT have GPF filters
  • The largest HJS tri-metallic catalytic converter that will fit in the factory location
  • This HJS catalytic converter will support 1200HP+
  • Designed to fit left and right hand drive cars worldwide
  • Significant performance gains across the RPM band, +22 HP and + 19 ft lb torque
  • Even more power can be unleashed with a ECU tune. Please inquire.
  • No tune required
  • Superior quality all German and USA components built in house by hand
  • TIG welded by our expert welders
  • T304 stainless steel
  • Fabspeed performance products are backed by Fabspeed's Lifetime Warranty
242286
1 - 2 of 2 Posts
