can I see this mounted on a Macan? thanks in advance.
A problem with these (and yes, I use one) is when your heat is on high it will turn your phone off. I hang mine as low as I can mount it to avoid this.
Not trying to be a smartass here, i.e., a legitimate question: are you talking about a vent-mount holder and, if so, do you close off the vent (via the thumbwheel above it) before use? I ask because, as I noted above, we use a vent mount, and haven't had any such problems (and have the heat on in the car half of each year, mostly using the foot-oriented setting on the panel buttons).I have one and you are absolutely right, in the winter it will overheat the phone.
Okay, thanks.Yes to both, I know it's no big deal, but I just don't like having to shut off a vent, lol. I originally used it in my Honda which has blowtorch hot heat, and even with the vent closed on that, it got too hot.
That looks reasonable.So I changed to get away from the heat problem using the vent approach:
Cheap and does the job.Amazon.com: TechMatte Car Phone Mount Magnetic-Dashboard Mounted Car Phone Holder-Universal Smartphone Compatibility with Strong Magnetic Technology (Black)
Buy TechMatte Car Phone Mount Magnetic-Dashboard Mounted Car Phone Holder-Universal Smartphone Compatibility with Strong Magnetic Technology (Black): Car Cradles & Mounts - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
