1 - 9 of 9 Posts
Hi everyone, I had an epic fail today trying to replace my air filter. At the end of the day I broke my new filter and had to put back my old one. The real issue was that I could not reattach the intake hose/pipe to the intake air filter box. I left the gasket off but everything else is bolted back in.
I drove the car and had no issues, drove about 30 miles on the highway, everything seemed fine.
can I continue driving without the gasket installed? How can I properly reinstall this gasket?
Picture below.
233346
If you mean the O-ring, you should install it back as dust and small debris can get sucked into the intake and going straight into the turbo.
Apply a bit of grease on the o-ring, if you don't have any grease use liquid hand soap, that's all you need to re install it with no issues.
Discussion Starter #4
Try this document and see if it helps any. There are some steps on reinstallation.
Thank you, I was using that for the install, it’s just that gasket that I couldn’t get back on. I’ll try again with grease, as her95b mentioned.
Are you unable to reattach the intake hose or the gasket? Or both?
Discussion Starter #6
The intake is on and screwed in, it’s just the rubber gasket that goes on the intake pipe/hose, I had to take it off to get the intake hose/pipe back on
I see. Well, let me know if you manage to resolve the issue - my Flat 6 Air Intake System is due to arrive next week so am hoping I don't run into the same issues with the hose gasket.
Discussion Starter #9
I would say try uninstalling and reinstalling the original one first to make sure you have the steps down and everything works well. I ended up destroying my Flat 6 filter because of it - thankfully Jon at Flat 6 is helping me with a replacement
1 - 9 of 9 Posts
