1 - 20 of 44 Posts
Macan 2.0 T
After two OEM turbos (Porsche/AUDI Part no. 06L 145 722D and 06L 145 722T; btw 06K145874E seemingly not better) had blown because shaft and internals were too weak for strong tuning (from 252 to 310 HP), a fully stabilized hybrid named: LM430 IS20 Upgrade Turbocharger, whose core can keep over 600 HP was installed. Also a downpipe with 200cell race catalyst and ic by Artek got thrown in as well as a software tune. Making happy & stable 410 HP since 2018 with very fast spooling. Cobb & JB4 are nice, but I wanted a 100% stable turbo. It is technically identical with bestselling LM440 Turbo but in the original AUDI / MAcan IS20 turbo housing: Spooling is much faster & much earlier and torque range is more intensive and linear than any other IS20 hybrids. Here some more technical info:
237610
LM430 Turbo Upgrade AUDI B9 A5 A4 A6 Q5 PORSCHE Macan 2.0T 180 KW 185 KW Hybrid Turbocharger ...jpeg
238275
Macan 2.0 T
Discussion Starter · #3 ·
Yes, stock engine internals.
R4 2.0 TFSI seems 45 kg lighter
Any Dyno sheet, boost levels etc. I know some will want to know more!
with this power ( depending on power curve) and lighter weight, you could beat a Macan Oem turbo!
Macan 2.0 T
Discussion Starter · #8 ·
Custome tune by TVS - They have lots of partners.
Your own tuner can also do it.
Macan 2.0 T
Discussion Starter · #15 ·
Hi, it's been installed since Sept. 2018 (ca. 42.000).
Regards
Macan 2.0 T
Discussion Starter · #17 ·
TVS.
Revo also provides software for it . Other tuners like tuning it as well because this hybrid makes boost very quickly:)
Tuners say that 2.0 TFSI Gen3 MQB internals are okay for at least 460 HP - depending on how agressive timing/ignition angle, etc. is programmed...
Normally they give it a rather soft tune of 400 HP.
TVS.
So adding a better turbo is what I need to do push 400 HP without much issues? I am going to do some suspension mods to make it handle a bit better and then do some power mods. What is the best hybrid turbo in your opion?
Macan 2.0 T
Discussion Starter · #19 ·
There has been only one really stable IS20 hybrid for 2.0 TFSI (Macan + Audi A5/A4 B9) = LM430 IS20 worldwide so far.
You can buy a different remake and after 4 months you will buy an LM430 anyway:)
(due to spool, stability, tuner friendliness)
What IC are you running?
Also, did you explore running a TTE480L?
Did you have to clock the LM430 or was it a bolt on fit?
1 - 20 of 44 Posts
