61 - 68 of 68 Posts
Same on a Macan S spindle
I currently have these
To me the cayenne and Macan calipers look identical?
Iv sources a set of cayenne GTS 390mm calipers
Ok for anyone who was wondering if a Cayenne GTS 390mm caliper will fit a Macvan. The answer is absolutely yes lol
Considering these are more available then the Macan 390mm set, this is an identical to it even though they have different part numbers
Obviously you will need the longer caliper bolts but thats about it. So yes. Cayenne GTS 390mm calipers will fit a Macan but NO you can not use the cayenne rotor being that its got a different offset. But the caliper is Identical to the Macan Performance Pack 390mm
2015 S, 1987 911
Discussion Starter · #63 ·
Very nice @Muckman
This is for sure great news for everyone following and looking to upgrade their calipers.
Yeh I might do a write up on it to make the question easier to answer instead of reading all though this thread lol
Yeh you can’t fit the cayenne rotors on a Macan so it’s either I go the Macan 390mm or the SQ5 380mm.
....it’s either I go the Macan 390mm or the SQ5 380mm.
One more option for you are rotors for the Audi C7 RS6 or RS7, which are 390mm with the same hat height and wheel bolt pattern as the Macan.
Reactions: Davin
61 - 68 of 68 Posts
