The question has probably already been answered.
here’s a reference from this thread when the 95.b2s came out.
Technical specs / data comparison between .2 GTS and Turbo. (Note: .2 denotes life cycle update on current Gen-I Macan) The table below listed the differences on specs without options. Other specs, such as Engine (2.9L V6), Power transmission (Drive system, Transmission, Gear ratios), Chassis...
www.macanforum.com
the turbo and gts engines are the same compression. So I think it’s really the same assuming the 2022 gts inherits the old turbo engine and the 2022 S inherits the old gts engine.
I was having a similar discussion in another chat on S vs GTS. The engines should be the same.
What was interesting is just performance after tune.
COBB Stage 1 tune numbers on 2022 S and GTS
2022 Macan S
Stage 1 93 Peak Gains : +15.33% HP, +13.9% TQ
Average HP : Stock: 279.9 hp; Tuned 320.6 hp
Average TQ : Stock 347.76 ft-lb; Tuned 395.48 ft-lb
2022 Macan GTS
Stage 1 93 Peak Gains : +2.04% HP, +14.53% TQ
Average HP : Stock: 302.56 hp; Tuned 324.54 hp
Average TQ : Stock 371.93 ft-lb; Tuned 401.70 ft-lb
After tuning... they are pretty much the same numbers for both GTS and S - with the S seeing the main gain mainly due to being detuned.
Other considerations though is GTS suspension tuning is different.
But a ECU tune immediately levels the playing field in straight line performance.
