1 - 7 of 7 Posts
· Registered
Not sure if this is a normal thing with the Macan GTS but when the car decelerates and it begins to reach the ranges between 2600 - 2400 RPM there is always this rough vibration right under the center arm console under the car and then stops once RPM reaches 2200 or less. Very weird, I can live with it if it's normal or maybe there is a mod I can do to minimize this annoying vibrations.
I've got 2000 miles on my GTS and aside from that I LOVE THIS BEAST!!
I saw this mod on Flat 6 website and was wondering if this might fix the problem... Powerflex Transmission Mount Inserts (Macan)
Thank you in advance!
· Registered
On order: macan S 2023, copper ruby metal, pp+, surround view, aluminum indoor finish, heated ws
my guy could not agree more.. i have macan s .. same engine though... but what a beast.. i am enjoying the ride
· Registered
I might suggest… Keep in mind if you install that and the dealership finds it, they’ll probably void the warranty. Then whether it caused it or not, and we all know it’s vibrating now, they’ll say the mount caused it any refuse to fix whatever the real problem is right now.
Take it in and get it on the record. In writing. If nothing is done it’s on the record should it get worse. IMO…
· Registered
Discussion Starter · #4 ·
Good advice... will do! Thank you
· Registered
Always in the same gear? If only in one gear, it could be a driveshaft vibration. Just a thought...
· Registered
Discussion Starter · #7 ·
UPDATE: I went to the dealer a few days ago and drove the 2022 GTS they had outside... Same sound at the same RPM. It's a PDK thing that people need to get used to... I was relived it wasn't something exclusive to my car. BUT I'm curious to know if there's any solutions to this... It's the ONLY thing that bugs me about this beast.
1 - 7 of 7 Posts
