Hi ZeroThis is an interesting thread. In my case my DD is a ‘22 X3 M40i. I am wondering if I’d be a bit disappointed with a ‘23 Macan S vs the brilliantly new B58 with mild hybrid tech, added in the ‘22.
$15K more for a Macan S and I‘d expect better all around performance in all drive modes not just better handling than the latest and greatest M40i from BMW.
I would think that they Hybrid would offer pretty good grunt.This is an interesting thread. In my case my DD is a ‘22 X3 M40i. I am wondering if I’d be a bit disappointed with a ‘23 Macan S vs the brilliantly new B58 with mild hybrid tech, added in the ‘22.
I sold my 22 M40i at 250 miles.The LCI 2022 BMW X3 M40i has a 3.0-liter turbocharged inline-6 motor coupled with a 48-volt mild-hybrid system, allowing the car to produce 382 hp and 369 lb-ft of torque. Turbo lag is virtually non existent. Kudos to BMW for adding this newest tech.
This 48-volt mild hybrid system provides up to 11 hp of extra push and enables the gas engine to turn off completely when the car slows down to under 9 mph. The system is also able to shut the engine off and "glide" at speeds between 15 and 99 mph and it works as advertised.
In my opinion, for the money, this is the best engines in the BMW stable right now. Looks are subjective…
The new S is suppose to be as quick as the old GTS. I have the old GTS and in E or comfort mode it's just fine. I'll admit that I have turbo lag, watching other cars pass me from a stop at a red light, but if I press harder on the pedal it goes. I know that the computer wants to see a certain engine temp first before it unleashes it full potential, which for me takes about 3 or 4 miles of driving from a cold start.So ours has about 600 miles on the odometer... The lag is terrible - push the peddle and wait wait wait. We're not racing around the neighborhood, but city driving in "normal" mode is almost dangerous. Strange and unnatural feeling.
From a stop , push the peddle while turning and out of the turn, 15 mph and going from 3rd to 4th. From a stop straight on, the lag is awful. Like a mushy marshmallow.
Definitely going back to the dealer on this one
WOW!Naw, no 1000 mile magic. EPA caused them to really detune the new models. Wife's 2019 is a beast, my 2022 is a puppy. Throttle Master helps but the power curve is all mellowed out for emissions. My $0.02 opinion and it's value may be less.
The factory throttle mapping sure is different than other cars but I have absolutely no issues with lag or what you describe. I passed 10k miles on our 22S a little while ago and it's a blast to drive. Takes a bit of practice and getting used to, like pressing the throttle a bit more, a bit faster, at the right time. It actually makes driving more fun to me. I can move very slowly and precisely but if I want to, it will launch extremely quickly.It’s a weird feeling floating into turns in 3rd gear. And more weird to press the accelerator and about seconds later it seems, the car starts moving.
Something definitely sounds abnormal. I went from a 20 Macan Turbo which had throttle response similar to what you're describing. When I got my 22 GTS it took me a while to get used to the more aggressive mapping. Admittedly it's not aggressive in normal mode, and now that I'm used to the GTS I generally turn it to sport mode before I leave the garage.So ours has about 600 miles on the odometer... The lag is terrible - push the peddle and wait wait wait. We're not racing around the neighborhood, but city driving in "normal" mode is almost dangerous. Strange and unnatural feeling.
This pedal commander you speak of will it void the warranty??Yes, the pedal commander will eliminate lag/hesitation 100%. The PC or a Roar Pedal can be turned up/down to find the sweet spot of response you want. I love it for an under $200 mod w/15min install.
I find driving in sport mode just keeps Macan S in 3rd gear around town and really winds out through the gears which isn’t the throttle response I was looking for off the line or cruising.
I will note, driving w/o a PC and only using the manual shifting, the throttle response has no lag b/c I ride in a little higher RPM and shift points.
I feel like my GTS has curves that are both shifted by about 30% to the right. There is a definite dead travel zone at the beginning where you push up to about 30% of overall travel before anything starts to happen.
Sorry - I must have missed your reply.... I had a 2006 911 C4S. While I dont expect it to act like that, it certainly does not act like any gas engined car ive ever driven. But, ive never had a turbo either. Its not a good experience and no fun to drive honestly. I cant believe I have to put it into Sport mode every time. Ive even asked the dealer to reset the engine learning ( cant remember what's it really called) to new. They told me at first the cars learn the driver and patterns and adjust from there. But when I asked about it, they said , no, its not resettable. I do remember it being done supposedly on my 911 once before.Something definitely sounds abnormal. I went from a 20 Macan Turbo which had throttle response similar to what you're describing. When I got my 22 GTS it took me a while to get used to the more aggressive mapping. Admittedly it's not aggressive in normal mode, and now that I'm used to the GTS I generally turn it to sport mode before I leave the garage.
Curious, what was your previous car?
Be interesting if someone on here has driven a 22 and 23 GTS to see if it's been remapped.
