I bought a 2021 Macan S and have some questions for you that I can't find answered here or in the manual.
1. I mostly listen to FM radio. Why does the (FM) radio turn off after a few seconds when I start the car and can I change a setting to keep it on? I can tap the white triangle to turn the radio back on but it is really annoying! I'm thinking that it has something to do with the wireless Apple CarPlay.
2. When I put the car in reverse the rear camera shows rear view in the PCM, but not the overhead/surround view unless you tap on the white triangle on the left side of the backup display. Is there a way to display the overhead view and the rear view without having to touch the white triangle every time you back up?
3. When I put in reverse to back out of a parking spot the forward looking warnings sounds. I consider this dangerous because I'm backing up and need to know about obstructions behind me - I'm not worried about the tree in the parking lot in front of me. So I start to ignore the warning signal and miss the warning about a pedestrian behind the car! Is there a way to turn of the forward looking warnings when in reverse?
Thanks.
Thanks.
