Hi all,
I took order of a new 2021 Macan GTS and noticed a few issues that I cannot seem to wrap my head around. It’s been in and out the shop several times already and nothing seems to be getting better no matter what repairs are done. I am currently dealing with 2 very strange issues.
Issue 1:
When starting the car and waiting for the engine to idle to normal RPM I notice a consistent stumble that occurs as the engine RPMs drop and can see a RPM fluctuation between 610-580ish once the engine is at normal idle. It almost feels like the engine is starving for air. During this stumbling you can hear it in the exhaust note and hear it from the front of the car as the engine RPMs fluctuate. This issue happens even if I drive the car and all fluids are up to temp. I did a 2 hour highway drive and arrived at my destination. Parked my car and let it sit idle for a bit and sure enough, the stumbling started.
I took it in for service and when sitting in the drop of bay you could clearly hear the exhaust note sounded completely off as if the timing on the engine was wrong. The SA acknowledged this and confirmed that this was not normal. He even noticed the RPM fluctuation. After service I was told that I had 3 bad plugs all on one side of the engine bank with incorrect gaps from the factory causing a misfire. I found this very hard to believe but who knows. The plugs were replaced, the car was road tested and I was reassured that everything is ok now.
After picking up the car and driving for about 30 mins I noticed the issue was not fixed and still had a very noticeable stumble. It almost seems worse now. The car is going back in for service but don’t like playing wack-o-mole with a brand new car and replacing part after part and maybe... fixing the issue.
Issue 2:
When car is in “Normal” engine mode and comes to a gradual stop the engine will shift from 2nd to 1st gear. During this shift the car lunges forward once the shift takes place. It’s not engine braking but more like a slight acceleration once the down shift occurs. It’s coming to a point that when pulling into a parking spot and creeping forward in the spot I have to be extra careful and time the shift and apply more brakes otherwise the car will lunge into whatever is in front of me. It’s a very noticeable jerk forward.
I was able to find another article on the forums about this that described my issue exactly but could not find a resolution or reason for it.
I don’t know what to do at this point besides just keep bringing the car in for service. Any advice or help would be much appreciated!!
Issue 1:
Issue 2:
