1 - 20 of 40 Posts
Did 1 launch mode today just to see whats up. Dang this car is fast for the non “turbo” model. It hits 1 G at the launch with some wheel spin.
236411
Is your GTS stock? Porsche says it is 4.7 secs 0-60 mph (4.5 secs with LC). You did good!
Reactions: MT15
Discussion Starter #4
BONE STOCK. This is my only attempt I bet it can cut a 4.1
Reactions: TripleL and Canuck
Discussion Starter #5
AutoTopNL timed the new GTS at 4.35s
So yeah, the GTS is a 4.3ish second to 60 vehicle.
This is to 100 km/hr. 0-62 mph. So Add 0.1-0.2 sec to my time.
Hmm wonder why there is a difference between the performance numbers of the GTS on the Canadian website vs the US website. HP and torque are the same but the Canadian numbers are .2 seconds slower. 4.9 to 4.7 with SC vs 4.7 to 4.5 with SC
Car and Driver’s review included a 3.9 sec. 0 to 60 mph launch. The car has some serious pop- and there’s a major difference in acceleration based on throttle input - boot it hard (maybe 70-80% throttle) and the car goes like a scalded ape; pulls a lot harder than it does with say 20% less throttle.
Discussion Starter #8
You can tell the engine is detuned around 5-6k rpm.
also.. if you look at the bottom left corner of the dragy it shows my time was 4.04 s with the 1 ft rollout compared to car n driver 3.9 (same method).This was my first launch on the car as i only have around 1k miles and i just pulled out of a gravel shoulder and gunned it. Crazy town
Reactions: 95B3.6
Geez, I can't believe it is going to be faster, in a straight launch, than my old 2009 911s. But that is why I got it. Cheers.
Maybe something with the standard features in Canada that the US doesn't have?
Must be the **** snow tires we need lol.
Supporting Vendor
Not bad at all. If you have a chance would you mind setting up a custom mode for 30-80 next time you do a pull? I'd love to compare from our library.
Our client's 2020 Macan S with a turbo upgrade did 0-60 in 3.85 which I'm assuming the GTS will be able to hit with a simple tune. I'd be curious to compare 30-80 to control for any launch deviations, etc. I was running Dragy on a 991 Turbo S today, 0-60 in 2.4! The Macan does really well in my opinion with the 0-60 run, even without sport chrono it can launch pretty good.
If you get a 1/4 mile run, don't forget to post here: Macan 1/4 mile standings
Discussion Starter #13
Yes will do. I dont think ill be anywhere near that. My macan does 4.25s 60-90 now. Ill rip 30-80 tomorrow. Whats a stage 1 first gen macan s run 30-80?
Probably because Canada refers to 0-100 km/h and the US refers to 0-60 mph. 60 mph is only 96.5 km/h (but I would be surprised if the additional 3.5 km/h added more than 0.1s, but that is what the reported stat suggests with a 0.2s difference)
Discussion Starter #15
For reference.
236433
Was looking through old pull data last night. This 0-60 is my 2016 macan S with the cobb 93 map. It did not have sport chrono. You can argue its slower because it doesnt have the aggresssive launch mode. However, even the 60-90 mph is slower by 1.5 sec (4.2s for the 2020 gts vs 5.7s the tuned 2016 macan s)! The butt dyno dont lie.
For reference. View attachment 236433 Was looking through old pull data last night. This 0-60 is my 2016 macan S with the cobb 93 map. It did not have sport chrono. You can argue its slower because it doesnt have the aggresssive launch mode. However, even the 60-90 mph is slower by 1.5 sec (4.2s for the 2020 gts vs 5.7s the tuned 2016 macan s)! The butt dyno dont lie.
What does 0-60 (1 ft) 4.53s represent?
Apologies, but a bit new to interpreting these data sets... everything else is clear to me.
Discussion Starter #17
This is the 0-60 calculated with the 1 ft rollout standard (how magazines do it). The first 12 inches or rolling dont count in this measurement-its like the staging beams at the drag strip. The actual 0-60 starts as soon as the vehicle moves (in the top center). The difference is the rollout time. Its an indicator of traction.
Discussion Starter #20
Stock 2020 gts 30-80 mph
236526
1 - 20 of 40 Posts
