21 - 36 of 36 Posts
Discussion Starter · #21 · (Edited)
BGB Motorsports ProTune
Captain's Log: Day 1, 03/31/2020
Version: 0
Vehicle
2015 Macan S
Miles Driven Prior to Logging
55mi
Gas
State: CA
Chevron 91
3/4 Tank
Observation
I don't know if it's the Monster I drank this morning, or the newfound exhilaration the car gives me :: hands still shaking :: o_O
The car feels as though it is in Sports mode all the time. The 1st 25mi of my commute I left the car in cruise at 75mph. When needing to pass I applied throttle, and magically the PDK downshifts 2-gears to pull ahead. It's as though John not only tuned the engine for performance, but also the PDK transmission at the same time. And mind you, this entire drive was not in Sports mode.
Power is now readily available, throughout every gear, while keeping that nice OEM+ silky smooth shifting
Takeaways
John and I will be further refining the tune for our not so perfect 91 gas here on the West Coast.
Discussion Starter · #22 · (Edited)
Captain's Log: Day 2, 04/01/2020
Version: 3
Vehicle
2015 Macan S
Miles Driven Before Data-Logging
33.3mi
Gas
State: CA
Chevron 91
Full Tank
Observation(s)
Wife: The car is much smoother. I can pass much easier. How much power am I making now? And how does that compare to a GTS? ...so I can tell my coworkers!
Me: Agreed! Let me see if we can find an AWD dyno in the area that doesn't break the bank.
Takeaways
Macan S v4 coming your way soon. Seeing if we can squeeze a little more juice out of our 91 CA gas.
Discussion Starter · #23 ·
A little fun gift to myself.
Accessories
SunCoastParts.com
Cup Holder Ashtray Insert
Overview
Tobacco or Change: Choose Change.
I was tired of searching for loose change whenever parking downtown. Voilà! Porsche to the rescue with non other than their ashtray insert which fits perfectly in our cupholders. You can buy similar non-branded items off other retailers, but the build quality will not compare to Porsche. But then again, what does?
230261
Accessories
SunCoastParts.com
Overview
Around Seattle they took away the option of coin operated parking meters. It was easy for them. They raised the price so high you need a platinum minimum credit card and you rent the space by the length of your car, by the inch. So instead of all those really cheap quarters now you are into lending programs. When I go there I take the Ducati.
Discussion Starter · #25 ·
Very nice! I'll never forget the 1st time I laid eyes on a Ducati.
It was the Fall of 2002 walking to class when I see not 1, but 2 yellow 998s parked side-by-side.
230262
What kind of Duck do you ride?
Discussion Starter · #26 · (Edited)
Captain's Log: Day 3, 04/02/2020
Version: 3
Vehicle
2015 Macan S
Gas
State: CA
Chevron 91
3/4 Tank
64.5mi
Updates
Uninstalled SprintBooster
Observation(s)
It seems as though my SprintBooster was giving some funky data-log readings. Uninstalled the SprintBooster this morning to gather new logs for John.
CONS -
With that said the car is horrible without the SprintBooster. I have to stab just to make the car go anywhere.
PROS +
On that note I was able to feel the effect of the ProTune without any additional nannies. The ProTune-alone continues to have the same --
1. Shifting: silky smooth OEM+
2. Power: nice getup and go throughout every gear
-- just without the pedal sensitivity and responsiveness as before.
This one is a ST-4S with about 42,000 miles on it. Not a garage queen.
Speaking of garage queens, here I am (in front), at Americade, 2012, shortly before a test ride on the then-fairly-new Diavel:
I liked the bike, but when I learned that the passenger was for photo purposes only, I was disappointed with the ride.
Discussion Starter · #32 ·
Captain's Log: Day 4, 04/03/2020
Version: 4, 5
Tune Updates
v4
-updates to power band
v5
-same updates as above
-updates to throttle tables
-more power added to partial throttle on gears 1-3
Gas
State: CA
Chevron 91
1/2 Tank
Observation(s)
v5: Good
Sauce is shifted back to under 4th gear >>
not quite a fan of the shifting
v4: Better
It felt as though there was less sauce throughout all the gears compared to v3 >>
shifting was better compared to v5
v3 (minus SB): Best
Nice power available through all the gears even though it meant sacrificing pedal response >>
which can eventually be fixed by reinstalling the SprintBooster module
Jon will be making more updates next week to add more cowbell.
If you guys can't already tell, Jon is a perfectionist.
We are already on 5 revisions and we aren't done yet until we get this thing just right.
If you haven't already, take a look at the Group Buy he's offering on the ProTune for all 2015-2018 S, GTS, and Turbos.
Discussion Starter · #33 ·
Captain's Log: Day 5, 04/04/2020
Version: Stage 0 v208
Gas
State: CA
Chevron 91
1/2 Tank
7.6mi over 25min Duration
Updates
Getting a baseline to validate --
1. How does the OTS tune/car correct for ignition timing?
2. Are the tune updates working properly?
Observation(s)
Now I really notice the difference between the OTS vs BGB Motorsports ProTune.
Discussion Starter · #34 ·
Captain's Log: Day 30, 05/05/2020
Version: Stage 4 v208
Final Verdict
I'm going on ~3-weeks of mixed city/highway driving for my 2015 Macan S.
VolcanoGTS said it best:
I can hit the pedal slightly and I’m in full boost holding the current gear to easily pass, a little more throttle and a downshift and gone. Mash the pedal and the front lifts like I haven’t felt this car lift before and MOVES.
I have also yet to feel any jerkiness that I have had in the past at low speeds, constant speeds, or taking off from a stop like a nanny which used to have hesitations and jerks.
Big thanks to John and his fine tooth comb attention to detail.
Do yourself a favor guys and don't settle for the OTS.
BGB + Cowbells FTW!
Discussion Starter · #35 ·
68,700 Brake Maintenance
Front/Rear Replacement
EBC Yellow Pads
Goodridge Stainless Steel Brake Lines
R1 Concepts Slotted Rotors
Motul RBF 660 DOT-4 Brake Fluid
242893
Lowering Springs
Eibach PRO-KIT Performance Springs (non-PASM)
242894
242895
21 - 36 of 36 Posts
